Rough Idle
Boston, MA
Drove home from work (~30min). Parked & shut off the truck to get the mail. 2 minutes later started the truck again and all of a sudden it was running so rough and stuttering. I've read a lot of the other rough idle posts here and seems for most it's either an EGR valve or fuel injector. Mine's a 97 LandCruiser. Think the recent bitter cold weather here in Boston would have anything to do with it?
Thanks for all the help.
Nisi
'97 Cruiser
You may want to try a bottle of injector cleaner in your tank first before you start pulling parts off. My 93
started to idle low and rough ~400RPM. I have 195k on the engine and I saw on another thread about the injector cleaner (i used valvoline) and it seems to have cleared things up for now and the idle is normal again.
thats all? ...injector cleaner and the vehicle is like new again?
valvoline injector cleaner is $35...nothing compared to what the dealership wants to charge
I had the same problem with low idle. It never seemed to run rough but, would sometimes idle around 450 instead of 650. I couldn't quite understand it as I always put the good stuff (shell, BP) in her. I ran a couple of cans of sea foam through her and it never really made a difference. Then I tried Lucas gas treatment, 9 bucks a quart at the local WallyWorld. She's run velvety smooth ever since. Idles at 650 and stays steady. It even seems to pay for itself in increased fuel economy as they claim on the bottle. If you want to try it, you can get the single tank bottle (treats 25 gallons, perfect for the 80) for about 4 simoleons. I never really believed in adding "snake oil" to good gas before but, I've been using Lucas for about a year now and it really seems to help.
