I have been reading through many older threads dealing with the rough/lumpy idle issue and due to the fact that my LC is exhibiting this behavior - slight miss at idle while in drive, almost feels like it will stall coming to a stoplight, smooth in the upper rev range, . I acquired my LC about three weeks ago and replaced the plugs, wires, distributor cap, rotor, valve cover gasket, air filter, fuel filter, oil, differential fluid, main intake boot, most of the vacuum hoses that did not look up to par, sealed an exhaust leak, belts. I also have a new pcv valve and oxygen sensors coming in today from the dealership. Everything I have used is straight from Toyota and no aftermarket parts.
That said, I still have a rough idle issue that seems to fall in line with what many people have dealt with on this board at some point in time. I ended up looking at the bundle of wires (harness) at the firewall and it looks like this issue has been addressed in the past. The wires that start to go from the firewall and snake through underneath the intake manifold have already been wrapped in heat wrap which is the common fix. My question is for those of you that have done this fix is how long has this fix lasted? My theory is that the fix might not have held up and I might need to go back in there and look at each connection again.
I am a little stumped. If it turns out the wiring is fine I can only think that it could be the AFM, EGR, or O2 sensors (will be replaced today). Any thoughts will be appreciated.
