rough idle in Drive
mankato, mn
hey guys. there is a long story behind where i am at in working on this truck but i have an immediate problem. the truck is running and idling great. 650 rpm spot on. when i went to put it in reverse to back out of the garage, it ran, moved, and idled great. i put in in drive to run down to the carwash to hose it off and this is when it started. the idle drops down and runs really rough. on acceleration it chugs and misses and is unable to go over just a few miles per hour. if you leave it in drive and stop it get really bad. when returned to neutral or park it continues to idle rough, unless you tap the accelerator, then the idle returns to normal and is fine. after its idling fine you can put it into reverse and it runs good again.
i just did the headgasket on this truck and it was running like this when i got it home but i thought it was from the water being sucked into it. it appears as though thats not the case. any help and and suggestions are welcome. thanks in advance.
mike
First thing to check is the intake hose. Check for cracks. If not that, then dry out the distributor.
Wet dizzy for sure. Oh, and check for the infamous crack in the intake tube...
thanks for chiming in Kliers. before i posted my question i read this: https://forum.ih8mud.com/80-series-tech/61744-idling-acceleration-problems.html and after reading i thought i better check the main wire harness. i figured that if other guys had problem like mine, it worth a shot. well, it was my problem exactly. the erg pipe had melted the wire harness and it so happen that when it was being put in reverse the engine would torque to the right and the harness pulled away from the pipe and when in drive the harness was laying directly on the pipe and shorting the one wire out and it was giving the ecu funky readings and that what my problem was. stupid on my part. i will be heading to Advanced Auto tomorrow to pick some of that heat shield up tomorrow to do the job right. a lesson learned.
mike
