Rough erratic idle
Crescent City, California
Noticed for the first time yesterday that when stopped in heavy traffic my idle was rough so I kept an eye on it. I notice the idle might be rough at a low 500rpm then for no reason jump up to 900 rpm then settle back to the normal 625rpm. This patten was repeated while at a stop in D or N.
Does this mean anything? Computer on the blink?
Michael
Was this soon after starting?
What happened when you turned the rig off?
Are you running on the original starter contacts?
No
Nothing
Yes
So do I need replace the contacts - I hear it;s almost impossible to get to unless you do a HG job
Check for cracks in the air intake tube for the throttle body.
have the same issue, new air tube though.
was told it's the idle air control valve....then was asked for 340 bucks for replacement part....
still living with rough idle , but intermittently.
Had similar issue. Problem was TPS (throttle position sensor) (thanks again CJF). I took it to a local shop because I wanted it hooked up to a computer for an overall diagnostic check. TPS was at 9 degrees instead of 6.5. I'm not sure how one checks and adjusts this, but the shop only cost me $80 for an hour worth of work which also included a TB cleaning. If all of your vacuum hoses and air intake hose are fine, I second taking a close look at the TPS.
good luck,
perk
I recently dealt with this Issue--was a few problems starting with a cracked air hose, one of my spark plugs was not gapped correctly(replaced all of them), and last but not least the TPS was bad according to the fsm. All is good now
Thanks. I may have found the problem in a gummy PCV vent hose
Where do you get a new(er) intake tube? Mine is also cracked at the acordian section and its temporarly fixed with duct tape...
Actually problem has returned - now idle is down to 400! I will go through the possibilities again. I'll get back after the weekend.
CJF: Yes it does and today when I started her up the idel went to 1500 and stayed there until she got warm. I'm on the TPS in the morning with the multi-meter
I've been having a similar issue. I changed my Air Flow Meter. That wasn't the problem. I followed that by replacing the TPS. Seemed to run better, but a little off. Mechanic said I should disconnect the battery any time an electrical component is changed to reset the ECU. When I did that the idle issue got much worse. Took it to the mechanic and he didn't do much but tell me he thinks it's the injector(s). He sprayed brake cleaner on an injector to see if it reacted and said it jumped each time he did and that would indicate a poor seal at the injector. I can understand that, but why the engine acted so differently after disconnecting and reconnecting the battery doesn't make sense. Didn't want to spend the money to have the injectors serviced without being sure ($1k plus in labor alone) so I limped it home and then removed the connectors to the Air flow meter and TPS then disconnected the battery and then reset everything. Started it up and it was rough. Decided to park it in its normal spot and while doing so it seemed to hiccup a bit and then began running smooth. Took it for a test drive to see. Ran smooth as silk. I thought maybe its fixed. Next morning same problem. Rough. Smoothed out a bit and idled at 400-500. As soon as it is in gear and given some gas it struggles big time. I have a newish air intake tube. Why in the world would this be so random?
