RockCrawler.com Rough Country Announces 6” Chevy Lift That Prevents Axle-Wrap
REVAMPED LIFT KIT NOW TO INCLUDE ANTI-WRAP REAR BLOCKSDYERSBURG, TENNESSEE— Rough Country Suspension ® Products announces an innovative addition to the popular 6” Chevy 1500 Suspension Lift Kit. Rough Country’s new pre-fabricated anti-wrap rear blocks are custom designed to prevent axle-wrap – a common issue where the axle rotates opposite of the wheel under torque [...]
DYERSBURG, TENNESSEE— Rough Country Suspension ® Products announces an innovative addition to the popular 6” Chevy 1500 Suspension Lift Kit. Rough Country’s new pre-fabricated anti-wrap rear blocks are custom designed to prevent axle-wrap – a common issue where the axle rotates opposite of the wheel under torque causing potentially severe damage to the vehicle. With a trapezoidal shape and wider surface area, these anti-wrap rear blocks are significantly less susceptible to wrapping and offer far greater peace of mind when towing or off-roading. This Chevy Lift Kit also includes a heavy duty skid plate, laser cut cross members, torsion bar cross-member drop brackets, and lifted knuckles. A set of front and rear Nitro 9000 Shock absorbers are included; featuring self adjusting Velocity Sensitive Valving - a revolutionary technology that varies the resistance valving incorporated in the shock according to piston rod speed. The 6” Chevy 1500 Suspension Lift caters to ’99 – ’06 4wd models and retails for $999.95. A non-torsion bar version is also available starting at $1199.95.
Link
