RockCrawler.com Rough Country 2012 / 2013 JK Longarm with Loop Exhaust
DYERSBURG,*TENNESSEE—*Wanting to beef up your 2012 – 2013 Jeep JK with the most durable and affordable Long Arm system on the market? Piecing together all the right mods for your late model JK is a wild goose hunt that can get very expensive. Rough Country’s new ’12 – ’13 Jeep JK Long Arm kits include [...]
DYERSBURG,*TENNESSEE*Wanting to beef up your 2012 – 2013 Jeep JK with the most durable and affordable Long Arm system on the market? Piecing together all the right mods for your late model JK is a wild goose hunt that can get very expensive. Rough Country’s new ’12 – ’13 Jeep JK Long Arm kits include everything you need to break in your brand new Jeep the right way.
JK*LOOP*EXHAUST:
New model JK’s saw a change in the exhaust design. The new factory location leaves very little clearance for the larger Long Arms and can make contact. Rough Country’s new Loop Exhaust Kit allows new Wranglers to experience the power of our Long Arm Kit by offering a very clean work around that allows maximum flex and keeps everything cleanly tucked out of the way. Included in all ’12 & up JK Long Arm Kits or available individually.
JK LONG ARM:
Gain the absolute best in off-road articulation and a host of impressive features with this all-inclusive package. There are no obstacles you can’t tackle with our front and rear Y-link Suspension setup featuring HUGE adjustable 2″ lower control arms and X-Flex Joints. This Dual Y-link Suspension setup with longer travel arms doesn’t just prevent binding and rear-steer, it gives you unparalleled axle flex while keeping pinion angles optimized – letting you negotiate trails on your terms. Combine that power with OEM style Clevite Bushings, Sway Bar Disconnects, and our Large diameter Performance 2.2 Shocks and you’ve got a rig that’s ready to go where most wouldn’t dare. The JK Long Arm Kit is built to withstand the harshes of off-road mayhem. A beefy crossmember with frame strengthening brackets gives your JK new, stronger mounting points while a 1/4″ thick steel skid plate keeps everything protected from off-road hazards. This kit also includes sway-bar disconnects, stainless steel brake lines, and adjustable front track bar.
CONTACT:Rough Country Suspension Products1400 Morgan Rd.Dyersburg,*TN*38024800-222-7023www.roughcountry.com/
Link
