Build ROTW: CDL question
Shropshire, England.
Website
www.crag-uk.org
I have a CDL button on the dash, its works well. I have unpluged the loom on the transfer box so it can be turned off in low and on in Hi.
Now to the question.
Can I do the "7 pin mod" so I can change between the 2 shift patterns in low? I now have the same shift pattern as HI, but before this mod the shift pattern was not the same. But of the places I use it over here I would like to shift between the 2 patterns. Is this possible?
Paul
Depends what you mean by possible, I guess.
It likely is possible, but if what you mean is: "Has anyone already thought about this and come up with an easy way to do it?" Then the answer may very well be "no". :meh:
Curtis
Curtis
I guess its a no then.
I will have a try one day, after everything in the pipe line.
Paul
