- Thread starter
- #41
A little update since April…
I’ve changed out the shoddy fabbed t-case shifter and linkage for a revised 2 stick version. The inner stick being for Hi-Neutral-Low and the outer for 2wd-4wd. The 2-4 stick is over bent and sticks into the passenger foot well a little more than I’d like so that will be changed when I pull it all out for paint and final welding. The throw on both shifters is VERY short which means they don’t need a lot of room for engagement, and I’m happy with that.
I also added a pair of rear storage boxes. I started with the passenger side box. It’s made entirely from 5/8 MDF and the front ½ is a sealed enclosure for my 10” Kicker sub which replaces the realestate hogging floor mounted 12” box that a PO had installed.
And the rear ½ is all storage. I have my bottle jack and siphon along with my air hose and fittings and a bunch of other crap hanging out in there. I attached a big sheet of Velcro to the back and used a couple strips to secure my tire spoons and another prybar. While I like this idea, the execution isn’t perfect and the tools located there will likely change over time
I plan to add a lid eventually. On top of that I used some Garage clips from Home Depot to secure my large prybar. I bought a stack of these and plan on relocating my short prybar and probably my breaker bar to the top also.
The Geneva tool box is mounted to the 1/4panel box and houses some of my tools.
