Rotor replacement
London SW15
My rear brake rotors have a small groove where the pad has worn away the surface of the rotor. Is this a sure sign of the need to replace the rotors, or can these take a new set of pads without replacing the rotors or machining ?
If the rotors are grooved then you should replace them and install new pads. Some will have the rotors resurfaced. I would consider that on the rears only... not the fronts as many (a LOT) of guys have reported their front rotors warped shortly after having them turned.
-B-
