I've had to replace the engine in my BJ60 out here in Sierra Leone, West Africa https://forum.ih8mud.com/diesel-tec...ne-swap-some-little-village-sierra-leone.html . The only 3B's available were rotary pump models much newer than my old inline injection pump model.
The rotary injection pump has a return line that the inline pump does not have. I ran the return all the way back to the fuel tank return using a small fuel line (I have an FJ60 pickup in a long range tank).
With the old inline 3B there was NEVER a priming issue except of course when I was stupid enough to run out of fuel.
Since swapping the engine I have had an issue with loosing prime overnight. I first attributed it to a poor quality primer pump so I bought another one in country, also cheap. The problem remained. I ordered a Delphi primer pump and a non-return valve for the fuel line from England to get something better than the dime store quality Chinese junk sold in Sierra Leone. The non-return valve came and I installed it at the inlet to the primer pump. Still lost prime. The new Delphi primer pump assembly came and I am STILL loosing prime!
Once the truck starts it starts easy all day. The longer you leave it the longer you need to crank which makes sense as it does loose prime. The next morning I need to bleed the primer and crank for a bit to have it go. If I leave it for a few days it becomes a bigger headache. More priming and cranking.
Where to look now and how to find this air leak?
