rookie needs help
ga
need to rebld carb for fj40 vehicle prod date 11/73 #on engine block 11411#directly under previous #60032, carb aisan 2-f-28,what do i have 2f carb on f engine if so is this normal,can anybody reccomend rebld kit for carb,and where to get it,any input helpful
Where in Georgia? Come to our club! Leaky Seals listed in the club section.
I would suggest that you send your carb out to be rebuilt. It makes things much easier and results in a much better carb. Jim C does great work as does mark (65swb45) both are on here.
I just posted about identifying my carbs not to long ago so as to rebuild. The number from what I was told is how you id the yr and month of your carb 2=72 f=june. That being said your carb wouldnt be a 2f carb. But thats assuming I understand the information I was told. Unless your a mechanic or have someone like I do (my dad) I'd agree with david and just send it for the rebuild. Good luck. Depending where your at in GA you might be closer to us here in Upstate Cuisers we are also located in the club section.
