@LandCruiserPhil What roof tent is that and do they provide the mounts to mount it to the OEM rack? I am trying to keep OEM roof rack and run a RTT
Sorry to revive the dead but I was wondering about your CVT tent, i inherited mine from the PO. Mine doesn't seem to open flat, is your doing the same or is it just the slop your on? Also I had to remove mine for the winder because it kept getting wet inside, the plastic cover doesn't seem to be leaking so it's either the zippers or the fabric under the zipper. Quite annoying.I got my CVT Shasta on the OEM 4 post rack but it squeaks quite a bit. Thoughts?
I had my bars mounted across the roof instead of front to back and the tent would hit the rail that was hanging over. As it, the bar was preventing it from fully opening. If you cut the bar to be flush with the base, you wouldn't have that problem. Let me know if that answered your question or confused you more.Sorry to revive the dead but I was wondering about your CVT tent, i inherited mine from the PO. Mine doesn't seem to open flat, is your doing the same or is it just the slop your on? Also I had to remove mine for the winder because it kept getting wet inside, the plastic cover doesn't seem to be leaking so it's either the zippers or the fabric under the zipper. Quite annoying.
NICE TENT!! WHich one is this?My RTT has spent 1000's of miles and many nights mounted to the factory roof rack
