Roof rack
Georgia
Anyone know of a low profile roof rack? I don't want to have to air down every time I want to get in the garage. I have about six inches of space to work with.
You will probably have to make one. If you use Bull dog clamps (like for a con fer rack) you will get about 2 to 3"s space before you get to the actual rack. Make your own mounts and you can probably get away with a rack that is 3 to 4 inches tall. But, if you want it real close and use a confer type rack, you may (dreaded comming) have to drill and mounting bolts through the roof and make some type of underneath support system to keep the top form cracking and falling apart. Honeslty, Unless you make some type of solid internal cage for the rack to sandwich between the roof, the top probably will not hold to that type of abuse.
Your best bet is to just put a rack on when you need it. Why drive around all the time with one on the top when you don't need it? Just put it on outside the garage for trips. Unless of course you just want to have it always on for looks. I understand that and not putting it down, but I also have to park inside a garage and cannot go over 33s (true 33s, or LTB 34 and have 1/4 inch to spare) and a SOA (only sits around 4.5"s in added height). I like to drive the cruiser a few times a week to work (keep fluids and engine fresh) and can't air up at 5 am just to go to work for the pleasure of driving the rig.
X2 on the removing the rack. If you can find a Confer porthole rack use it and the Thule arms/bars. The bulldog clamps are great, but tend to chew up your gutters. The Thule arms are lockable and easier to remove. You can usually find good used ones on Ebay.
