Roof rack systems
Powell River, BC
What kind of options are out there for 80 series roof racks? I have no factory rack on my 81 and could use the extra storage space.
I have briefly looked at the Yakima/Thule gutter mount racks, but they seem to sit rather high off the roof. What other systems are available?
Then once a rack is in place, there is that whole "what kind of basket to put on top of it" issue.
Jeff,
My favorite is Aiba Works.
I believe them to have the most versatile system available in Japan, with most variations that I've seen.
If you have somebody who would put one in a container for you I would be happy to make the arrangement for ya.;)
Here are some examples.
Last ones...
They have various lengths and you can pick and choose the mounting leg lengths/heights as well.
Most of their models are made of aluminum, so rust is usually not an issue (They also have stainless steel option on at least one model).
They say they're rated only for 30 or so kgs, but they are WAY more sturdy than that. (As strong as your rain-gutter or the pillars would allow)
I have seen them on trucks exported/imported into Canada, so you might be able to pick one up somewhat locally.
GOOD LUCK!!
the ones that come oem from jdm's are nice. they pop up on CL from time to time.
i was looking for one of those..but i ended up piecing together a yak/thule system. the arb & AO's were too spendy for me at over a grand.. so got 4 load bars & 8 gutter mounts from thule, and scored a yak loadwarrior + extension setup for a straight trade for my skybox. longer but not as wide as the jdm ones. thinking of adding another extension + more mounting brackets to make it full length. was hoping for the full width megawarrior extension though.
the thule gutter mounts are pretty low profile...and the load bars are fairly close to the roofline, id say about 1.5"...2 max. there are higher mounts available from thule, and the yak guttermounts are quite a bit higher than my thule's.
the thing i like about the load bar/basket setup is that its more versatile...can still run bike/board/kayak/etc mounts, things like full length 2X4's and ladders etc. can go with 2/3/4 bars depending on what im carrying. you're not limited to the baskets dimensions.
Thule Yakima
The only reason I would stay away from the thule and yakima racks is I've had both... ripped them off on multiple trips on trees or rocks:doh:. If you're wheeling the rig at all a JDM is tighter to the center of the vehicle or a custom can't hurt either:hhmm:.
i've gotta african outback roofrack from slee if u wanna come take a look at it
