Rol-Air air compressor
Belmont, California
Was shopping for a new air compressor to keep in my garage because I need to completely deflate my tires to get my 40 in and out of the garage. My old two tank emglo compressor is on its last legs. I was looking at a few brands and ended up buying a Rol-Air compressor:
http://www.rolair.net/products/spec_pages/hand_carry/D1500HPV5.html#specs
Are these good compressors?
Fini
that compressor unit is an Italian made FINI
not bad.. not good either. reed valves , direct drive,
For limited use it should do fine.
The delivery would suggest it is actually closer to 1hp than 2.
There is nothing like a little air.. but once you have had a little
'you will crave alot.
FWIW I've seen lots of framing and roofing contractors in the area running similar Rol-Air units. Most like they've been through battle but are still plugging away just fine.
