I did a valve adjustment, but it looks like this part is something the PO added. Can anyone identify this part and give me more info about it? Oil comes out of the sending unit to a copper tube, and connects to the rocker arm assembly via this part. Oil comes out the rocker arm assembly and also comes out of the bottom of this part. If I plug this part with my finger while the engine is running, I get better flow out of the rocker arm assembly-- anybody else familiar with this? I welcome any advice!
Thanks, Brian
Ed
Thanks for the quick reply's. The picture makes it look like a screw is located at the bottom of the banjo fitting. Mine is missing. That explains why oil pours out of that hole. I will try to get on at SOR thanks again. It is very nice of you guys helping all us rookies.
Thanks Again
Brian
Ed
Thanks Again
Brian
You might want to check on the "Wanted" section first. or contact Mark Algazy at Marksoffroad.net
Mark has a huge inventory of F parts and will give you a wealth of information.
Shipping and minimum order $ at SOR make ordering a single part pretty expensive.
Been a while since I messed with the new motors..........
That "screw" that is missing keeps the banjo from walking left or right by occupying the space between the rocker shafts. You should be able to get a metric screw and lockwasher at a hardware store. Also check that those rubber seals at the banjo are still sealing. It is supposed to be at the top of the banjo...............
So I just reread your original post. The previous owner did something here.......... The oil line is supposed to go down through the head behind the pushrod cover on the side of the motor and tap into the block at the cam............not to the oil pressure sender. Either it broke down there and he didn't feel like pulling the side cover, or there isn't enough oil pressure at the cam and he got some advice from an old timer who worked on Chevy stovebolt sixes.
And not to panic you, but..........get an overall shot of that motor so we can ID it............methinks it was a mix and match job...and may be an early head on a later motor...
Jim
I think that you are right. I should have said that there was a hole drilled in the valve cover and that 1/4 copper tubing goes through that and into the banjo fitting. When I plug the hole at the bottom of the banjo oil comes out of rocker assembly quite nicely. I will post a picture. Thanks for the help.
Brian
Yep, hopefully one of the guys who knows the later F motors will chime in. If an earlier head were used on a later motor (that is normally fed through the rocker pedestals) you'd have to rig an oil feed. No idea on the years though.
Running it through the valve cover is one way, this is a little cleaner but the same idea:
