Rocker arm disassembly question.
Louisville, KY
Hey guys. I am having an oiling issue on my top end. I started the investigation by pulling the rocker arm assembly. I want to disassemble and verify that everything is correct and that there is good clear passage for oil.
First you will notice that there is a prettty thick layer of funky oil residue on everthing. I'm assuming that this is not a great sign. But.... when I go to disssemble the rocker arms and springs, the two end arms seem to be getting hung up on the end of the shaft. I assume that this is not normal. See the video below.
I cleaned the end of the shaft with carb cleaner and it seems to be clean. It seems like the rocker arm bearing is hitting a lip or something. I was going to lightly sand it (the end of the shaft) with some 600 grit. Thoughts/suggestions?
Keep at it, oil needs to get to the rockers,
Video clearly shows a burr at the 11 to 12 oclock position, looks like it was hit or dropped hard???
May need to grind down the blemish to slip the rockers off,
Surprisingly, that feature is on both ends of the shaft at what appears to be the same clock position. Possibly a result of manufacturing/initial assembly? Has anyone else seen this?
Not a manufacturing defect it had be assembled, By chance did u not pull off the the cone spring and hair clip??
Maybe a PO or tech in a hurry peened the end of the shaft as a means to keep the rockers on,
If you take everything off the rocker shaft, be sure to get the shaft in the way it came out. The oiling hole coming through the rocker stand ( #3 if I remember correctly) in the head has to match up with the hole in the shaft or it will self-destruct in short order.
Just had to disassemble my 1F valve train and had the same issue. It was easier to remove each half and then remove the clips, spring and rockers from the center rather than the outer ends. If the trains are similar....
The center joint slides to the rear half once the screw is loosened. Oh, and take the oil line off before removing it.
I had an incident where my rear half was installed 90 degrees off which caused the oil ports to line up with the rocker ports and gush oil. There wasn't enough head pressure to push oil into the front train. Once I figured out that, the front oiled great.
@texasgreenhead thx for the comments. I think there are some significant differences between the 1F and 2F designs. There is no center joint or copper line connection to the rocker arm shaft. It is oiled through one of the pedestals.
I was able to use a die grinder with a 120grit pad to clean up the mushroomed portion of the end of the rod. Everything slides off freely now.
Going to clean it up tonight and then drive the pump with a drill and see how the flow it up through the head w/o the rocker assembly installed.
You won't get any flow unless the cam is in the correct position to allow oil though its galley.
