So with the advent of tube buggies and thinking outside of the box, why not use Hydralic drive hubs? ......... like some heavy equipment use and farm sprayers to attain the crazy ground clearance of 6- to eight feet+ undereath. the units could mre than handle the force of the biggest DOT tire you can throw at it, as well as the shock load of spinning and grabbing traction is transfered to hydro fluid and not a hub backed by a axleshaft backed by a diff. backed by a driveshaft... I could keep going but you get the point.
the tires could actually run independent/turn of one another as well as be "tilted" to accomidate an incline/angle etc.
a small engine to drive the hydro pump for weight and unlimited number of moutnig options for COG (center of gravity) weight displacement.
Pro's?
Con's?
Pro's?
Con's?
