Rock Box or Toy Box
I know it's been discussed before but I can't find enough info on the rock box so what do you all think trying to decide between the rock box and the 4.7 toy box.
I'm planning on using a stock 4spd. trans to (crawl box ) to 3spd. t-case.
So let's hear it anyone had both ?
Thanks
Burl
I am just finishing up a 465/toybox/orion install in a '69-40, moved the rear axle back 6.5" to accomidate the toybox. (truck was originally a 465/three-speed case set up) After working with Marlin and getting the Toybox/465 set up dialed in, I would say go for that, as it is a really nice product, has been used in hundreds of mini-trucks for years, and should work out really well in the Land Cruiser too.
Good luck!
-Steve
I used to like the Rock-box but after working with both I think I'd lean towards the Toy-box. Marlin makes a great product.
The Rock-box doesn't have as clean a record as the Toy-box.
Toy-box has more gearing options...
Toy-box is easier to keep oil in...
Thanks for the replies guys I'm leaning towards the toybox also but wanted to hear some other opinions
Thanks again
Burl
any more thoughts ?
IMO, Toybox....that was my direction until I opted for the D300...
have the mini box and a split case on the floor with no future now...lol
Toybox Experience
I can only comment on my experience with the Toybox between the SM 465 and 3-speed T/C. No problem in over a year of running Rubicon/Fordyce/Dusy/Hammer trails in my FJ-40. Shifting is smooth, and the box is quiet. This installation allowed me to get rid of the old style AA adapter between the tranny and T/C (Toybox almost exact same length), and also I got rid of the old crossmember hanging off the back of the T/C. I built a new one right under the Toybox.
I did experience a pleasant surprise with the lower gearing. Since I use 1st gear of the tranny much less frequently, I'm able to take advantage of the synchro shifting in the other gears. So downshifting (other than 1st gear) is a real breeze. Sure, the Rockbox would offer you this same benefit. Although the 294:1 crawl ratio is kinda ridiculous, it has come in handy. The gearing options are worth every penny........
I plan on running a toybox behind my 2F and stock 4 speed. I was wondering about the requirements for a cross member under the toybox. I thought it might be a little too much weight hanging off the bell housing mounts. Not that it is a lot heavier, but the leverage imposed by moving the tcase back will increase quite a bit too. I have been expecting to have to fab a cross member and just wanted to comfirm that.
This is something that you will need to do. The added weight and leverage of the crawler box on the flywheel housing will only lead to sorrow if not.
Good luck!
-Steve
Good luck!
-Steve
Thanks, I thought so. And I'll need that luck to get the permision to buy it.
Just wanted to say thanks for the replies and I think once I get my tax refund back I'll get the toybox so where's the best place to get one from straight from Marlin ? or are there others who sell them ?
Thanks
Burl
Toy box all the way. just machined the clamp collar for the 19 spine H41 output shaft sitting on the bench and need to finish buttoning up my second toybox. get a newer mount for under the reduction box and if your using the 4.7 gears get the new spring from Marlin that's stronger.
i have split cases on mine but the instal should be very similar. gears are good! i actualy plan on putting a mount under the minibox and the H41. marlin sells a mount/skidplate. if your using a female input gear in the reduction box make sure you get your core from the man marlin himself, the OD of the bearing for the female input gear is a touch bigger than the Od of the normal 21 or 23 spline minitruck input.
When I say new spring I'm talking about the detent spring that goes on the shift fork for the reduction unit. With that much torque it might pop out.. Marlin sells the spring for about a buck? Don't know if he even charged me for the last 2..
Thanks Woody , Tornadoalleycruiser and everyone else for the info.
Burl
