Road trip maintenance...
Ashland, OR
Things, $$$, have been tight this winter so it is time to catch up on maintenance before the big summer road trip. Our big trip this summer will be to Park City for some R&R. We should put @ 2,500 miles on the truck. Following is what I have planned:
Birf job
Full cooling system flush
New thermostat & gasket
PHH
Radiator hoses
Belts
Synthetic atf flush
Fresh lube in all diffs
Brakes worked over
VC gasket and spark plug tube seals
Spark plugs
Slee light harness
Scanguage II
Rotate tire & alignment
The only things I feel I have left out are the blue fan clutch and a new fuel filter. The truck has 140k on it and short of an hg job I think I have covered my bases. I have invited some local mudders over for a weekend of wrenching. As usual the mud community is ready and willing to help out.:cheers:
What are your summer road trip plans and what maintenance will you do?
My road trips are limited because of the little one's.
This did get me one time only a few hours from home. Don't forget to check the spare pressure, AND make sure you have a jack avail that can reach with the 285's.
Just my two cents. I noticed that every time I install something new on my rig, something breaks down or fails somewhere else. I would make sure I drive a couple hundred demanding miles to check that everything is in order after such a service.
Since you asked, as far as my Summer trip is concerned, I'm leaving next week to Yellowstone and Grand Teton NP for what should be a 2,500 mile trip in 12 days.
I already had the truck baselined for a hefty price:crybaby: before my Spring trip (1,500 miles around the Grand Circle last April). An oil/filter change, tire pressure checks and some lubing would do the trick this time. Plus a road assistance card in my wallet, of course.
We'll see how the 80 behaves, hoping it'll stand a nice 2,000 mile fall trip in Moab. Yep, I have A LOT of holidays - 51 days a year.:flipoff2: (sorry, couldn't resist).
This will be the first big road trip with the 2yo twins, should be interesting. Good point on the jack. I need to test the lift hight.
Thats ok, I worked 50 days last year.:flipoff2:
Maybe that is why I can't afford the cheese on a cheese burger.....:hhmm:
stock jack is fine if you lift using the axle tube.
As far as pre-trip maintenance, I'm not a big believer in that. In fact, I spent 2 hours in a parking lot working on a hub in moab because of 'pre-trip' maintenance.
Change the oil, air filter, and plugs if you get the itch. Leave it at that. Or, top off your birf grease through the square plug. Gear oil is cheap enough, change that too....
I would certainly NOT tear down a birf before a trip unless you were planning on putting at least 200 miles on it before you left.
I hear you on that. I have experienced a few fix it and run problems in the past. I will have plenty of time to get everything settled in. I have a guide date the day before we leave on our trip. I will be up in the mountains scouting at least twice before that. Plenty of opportunity to get stuck "out there" before our road trip.
Alot of what I am doing is purely overdue maintenance. The road trip is just an excuse to spend the $ on getting it all done.
My summer road trip is Grand Canyon, Lake Mead, Salt Lake City (World Superbike / AMA weekend at Miller) and at least a pass through and look around in Moab. The cruiser is new to me and since I had shoulder surgery I have not been able to do much from how I got it. PLUS found out the otherday she needs some (lots)ac work done. So we might be taking the wifes 2wd four runner. Which would limit the moab excursions. I too will be traveling with the roadside assistance card in hand.
i am not an expierenced cruiser mechanic and i have a couple of questions: Thoughts on k&n filters? MAFs?
and does synthetic fluids make a big difference? Are they worth it? Thanks in advance. Bonfire
x2...just drive the dang thing...save money for gas, it's a TLC.
I agree not to get too carried away unless things need it. Couple thoughts: air filter, rear wheel bearings, lube drive shafts, flush brake system, HIR bulbs.
My thoughts:
Stay away from K&N. They definitely let oil into places you may not want oil. The factory foam works great and is washable. I have two and rotate them in. I washed one yesterday and it is in today.
MAF's????
I use synthetics in all of my fluids including brakes. Some will argue that the cost is not worth it. I figure that if it will help over the long run. If not I will never know. BTW, when I switched to syn ATF I did notice an improvement in shifting. I also buy my fluids wholesale through my company. Makes it a little cheaper than buying M1 though wally world. Besides, OPEC gets enough of my $ through gas purchases.
:cheers:
If I were you I would skip the light harness. I am NOT knocking the product in any way, as I have no personal knowledge of or experience with it. However, I can tell you the one of the last things I would want to troubleshoot in the middle of nowhere in the middle of the night are my headlights.
Just food for thought.
I'd be sure to get at least a couple hundred miles on your work before heading out as mentioned above.
I replaced the fan clutch the night before my 2000 mile trek out to Moab, and by the time we got to Columbus my belts were loose because of a broken lock bolt. Had it not been for a 3 hour lay over at a Toyota dealership there, we would have been heading back to PA, very slowly.
more dumb questions
My thoughts:
MAF's????
:cheers:
I thought that was the problem with k&ns was oil on the mass air flow sensor? Or am i confused? I only ask because the PO had installed one in my newly acquired fzj80. And I was wondering if I should leave it.After reading a few posts it sounds like I need to go buy a OEM filter or two. Who gives discounts again??????:D:wrench:
Cruiserdan at American Toyota. The contact information can be found in the Advertising vendor section, see link upper right of every page. Dan is option #8 in the parts department. You might as well buy some of the big oil filters when you order. They can be hard to find locally.
I put the new Scanguage II in yesterday. I highly recommend this tool to everyone who is OBD2. I wish I had bought it sooner.
Thank you for the tips. I really appreciate you guys who know what you are talking about.
I have been researching the PHH. Flyrod, you have a silicone PHH? Was that easy to find? Or is it aftermarket. I want to replace that one in the driveway one saturday instad of the alternative. And when I go through all that troubkle, I want it to be as durable as possible. Thank you again for helping out a newbie. :cheers:
Honestly I wouldn't let potential failure stop you from doing this mod. IF, and that's a big IF, it fails then just plug the lights into the old harness. You aren't removing the old harness. Just not using it. Its still there waiting to have lights plugged into it.
It's not the potential failure that bothers me. It's the potential failure of a new modification not tested before a long road trip. By all means do the mod, just don't do it in preparation for an extended trip away from home.
