I was wondering if anyone out there knows if you can pull the no. one cylinder piston without removing the main crank on a 302. I was told it could be done, but im right there now, and it doesnt look possible to me. i dont really want to pull the entire crank out, nor the engine. had a valve prob. with number 1 fixed it and believe as a result of that prob. no. one rings are jacked. this is a daily driver, and need to fix asap. any insight would be appreciated. also, i tried the trans fluid down the carb trick, and it did not work. any suggestions?
