rim interfering with drum bolts
Sunny South
i took the wheel off to inspect the brakes of my new 40, because the rear brakes needed to be adjusted badly, they were terrible on the road but it appears the they have new wheel cyl.'s which is a plus but when i took the wheel off the drum just slid right off with noooo hesitation or force used to pull it off, after a close look it looks like the PO didn't put the 2 bolts back into position to hold the drum snug to it, well it looks like the reason he didn't is because the rim wouldn't go on because the 2 bolts would interfere, with there not being to 2 holes for the bolts in the rim it would be impossible to put them on ...
so is it ok to run without the 2 bolts on securing the drum in place? or is there any fixes ?
i'm also not running stock wheels, there 36" tsl's
Yes it's ok to omit the drum retaining screws.
I suspect your lack of braking is due more to needing adjustment. If your drums slid off that easy, try adjusting the shoes and see if that helps.
I took em off my drums, they I recall dont hold the drums on, but are just hole to put a bolt in to help get the drums off.
