Rim Help!! Will these work on the 80???
Calgary Alberta Canada
hey Guys just wondering if these would work on the rig. They are 2002 Sequoia rims!!
Four wheels from a 2002 Toyota Sequoia Limited. 16 x JJ (not sure what this means!!)
I thought I would paint these if I can find out if they will fit right! any help out there??
Thanks again,
The only mod to fit the later model Sequoia rims is some minor machining in the center to open up the center hole as the 93 up 80 series wheels are hub centric, meaning the hub centers the wheel not the lug nuts. I imagine the earlier Sequoia wheels would be the same since Toyota did not change the drive train significantly on the Sequoias current run. That would be your worst case scenario, I think they will work on your 91 HDJ. IIRC the 91-92's don't have hub centric wheels. If you have access to the Sequoia wheels I would pull a wheel and try to bolt it up.
