rigid duallies side shots
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
k, heres the deal I got two sets of rigid sideshts they both comes with wiring harnesses w fuse,switch outputs. I took the lights adaptors cut them off and soldered two and two so I can have one run one switch one relay as soon as i lit em up fuse puffs, doubled it puff again, what did I do wrong>??
Maybe draw us a picture? Saying that your fuse is puffing isn't a whole lot of diagnostic information to go on
cmon Joey exPAND on that im hookin st8 to battery as rig is disasembled like jonny 5
You let out the magic smoke because somewhere along the circuit it got shorted. Without pics, schematics or anything else it's kinda hard to determine ;)
As an electrimagician, I can say that you should just keep putting a bigger fuse in until it stops blowing. Or don't even bother with a fuse because fuses are for pussies.
Or, you know... gimme more to go on here. How many watts are the bars rated for? Draw a schematic showing how you're currently wired up, and maybe some pictures as well.
You jinxed yerself when we talked lights & said "I'm not paying for that re:Rigid".
They just showed you they own you, not vice versa.
Seriously, I'd backtrack & make sure each light & component is good since it has to be a simple fix.
Were they open box returns / similar -to be a good deal? That's what makes me think you need to test each part, then build out.
