Rhino Rock Sliders bad install
Israel
Hi All,
I just finished installing the Rhino rock rails on my LC200 as a shop that had experience with such installations.
The gap between the body tne the rail on the driver side is not equal to the gap (or no gap) at the passenger side (which looks OK).
To my comment thet shop expert said there is not ability to control the location of the sliders since its mounted to the frame (no playing or adjusting).
Picture attached.
What's your advice? should I send the installation pictures to Rhino for a solution?
Thanks,
Aifer.
I haven't installed those particular sliders, but most have some slop in the mounting bolt holes for just this reason. loosen all the bolts up a little, put a jack under there, jack it where you want, and re-tighten. Worst case you might find that you have a few holes limiting movement and those need to be opened up a bit but that should fix it. I'd question the capability of a shop that says they "Can't" fix that, but it is possible that they don't want to spend anymore time on it.
