Rhino Rack - Fox Wing
Kelowna, BC
I was asked about Rhino-Rack and the 270º Fox Wing I have. They are available in left and right side configurations depending on what side your single swing out is located. The big advantage for me is they are much easy to install poles, because it is already above ground, hanging from the swingout hinge. MSRP is $700
Rhino-Rack Product List (Australian) - they make a lot of stuff.
http://www.rhinorack.com/en-us
Only thing I've notice on theirs that is different from the square/rectangular units is that you have to keep the upright posts separate from the rest of the awning. That part sucks a little as it requires additional storage. The nice part is you can replace the upright posts with the ones from drifta with the built in LEDs and batteries.
http://www.drifta.com.au/led-light-pole-kit/
I would not want LED poles shining in your eyes - for me indirect light works better. I got the 8' Lee Valley Led ribbon strip and cut 48" which I installed on the bottom rear window lip (angled toward the cargo area) providing indirect lighting down on the tailgate and cargo area. I experiment at night and found direct LED light above you head shines into the eyes was way too harsh and I could not see anything. It must be indirect light. Also installed the off/on dimmer at the tailgate so I can have bright task lighting making dinner and turn it down to find my way home from the campfire.
I also installed a two-conductor pigtail plug to I can install the remaining 48" LED strip under the Fox-Wing. Even the 48" strip produces a lot of light cranked up. Rob Millson gets the credit for the idea
