I recently rescued a crusty-bodied RHD 1HD-T/H151 and was wondering how many additional parts will be needed to swap over to a LHD Auto set up.
I already have the driveline out of the LHD Auto and was planning a different swap but...
I'm mainly curious about what swapping the transmission to the other side needs. Obviously the gear shift needs to point to the left instead of the right. Do the RHD & LHD share the same bell housing? Is the slave cylinder on the same side on both? Are the motor mounts different btw the LHD & RHD trucks? Will the pedal assembly swap over easily enough?
Or should I just sell you the whole truck & let you do the swap?
