I just wrapped up a major overhaul of the wiring harness on my '76 FJ40. After five decades, the factory copper was looking tired, so I spent some quality time repairing what was salvageable and cutting out the rest.
The Upgrades
The goal was modern reliability without losing that classic Land Cruiser soul. Here is what I’ve finished:
Fuse Panels: I ditched the old glass-tube fuse block by the clutch pedal that began disintegrating every time I touched it. In its place is a modern ATO panel with plenty of expansion room.
Engine Bay Power Distribution: I installed a dedicated fuse/relay box under the hood. This now manages the Vintage Air A/C, a new HEI distributor relay, and my front bumper lighting (fog and 4-inch spots). I have a relay pre-planned for an air compressor, and have 2 more relays to spare. To fuse the different high amperage circuits, I bought a 1-in, 6-out ANL fuse block. I realized that was a mistake because I needed 2 out circuits, so I modified it to 2-in, 2-each out.
The Big Three (plus one): I swapped all power and ground cables for larger gauge wire. I also ran a dedicated charging lead from the alternator to the battery through the ANL fuse block.
Winch Safety: I added a fuse and 500-amp relay between the battery and winch. I am nervous about having any large cable unfused. To use the winch, I flip a switch inside to power the relay, winch sends power to the winch.
Safety: Added a fusible link between the battery and the interior panel for peace of mind.
The "Aha!" Moment
I discovered the Previous Owner had actually plugged the headlight harness into the switch backward. There isn't a keyed connector to prevent this, and reversing it instantly fixed a bug where the headlights and parking lights were firing simultaneously on the first click. Also, now my dash lights work.
The Remaining Gremlins
I still have two electrical hurdles to clear before I can call the "smoke" officially contained:
Wiper Woes: The wiper motor only has "fast" speed and refuses to self-park. I looked at this the other day, and it looks like the original motor because the factory wiring there actually looks good. I have to do a little research to see how this circuit is supposed to work. Maybe this switch is also plugged in backwards.
Oil Pressure Gauge: The needle hasn't budged. I’m planning to swap the sender first and pray the issue isn't buried inside the gauge cluster itself.
If anyone has chased these specific wiper or gauge issues on a '76 recently, I’d love to hear your "don't do what I did" stories.
I seem to recall that there's a test procedure for the oil pressure sender and gauge outlined in the chassis manual.
If the other gauges are working correctly then it's likely a wiring or sender issue.
