Rewiring a 40
Northern California
Been reading through all of search results on rewiring a 40. The consensus seems to be that if its higher amps than stock(eg lights) then an upgrade to 12 guage is advised. My question is why not wire it all in 12 minus the obvious(alt. lead etc) This is on the 40 with 350 and two optimas. By the way the exchange on mobi vs bluesea was entertaining to say the least. Whoever suggested Waytek needs to be thanked. Just bought all kinds of goodies from them and the minimums vary based on item. Switches were about 7-8 and wire was 100ft spools. Anyways, any real downside to 10guage? Thanks Eric
12 Guage
There is nothing electrically wrong with running all 12 guage wires. You will have trouble with the pass through in the fire wall and the bending of the wires so they look nice once done. It is a bit of overkill on most things. Also, if you run 12 guage wire all the way to a component and then the wire that goes into the component is 14 or 16 guage you are not gaining anything. It will be restricted at that point.
Just remember to fuse everything at the connection close to the battery. If a hard short occurs the wire may not melt, wrather it will become a light filament and most likely start a fire.
