reverse slips after 2000rpm
If i put the pedal to the metal in reverse if only goes 75 feet befor it reaches adout 2250 rpm and then just wines and loses all power,my 93 80 series is automatic. is this the clutch? transmition? the transfer case is wet not dripping so dould that be the problem. I feels good as long as i keep revs low. can some one give me a diagnostic, or has this happened to some one ealse and what did you need to fix? how long will this part last befor it goes altogether?
Have you checked your fluid level in the tranny? My understanding (strictly based on the members here) is that the tranny is sensitive to the amount of fluid...too little-slippage; too much-early failure. How many miles? Have you experienced the same going forward? Try putting the tranny in low (1) and see if it slips at a similar RPM? Where are you heading in reverse at that speed anyway Mad Max?;)
