Reverse lights
Utah County
I have a short in the wiring harness that I was told was caused because coolant leaked from the heater valve down on to the harness. Now I don't have any reverse lights. How hard is it to access this harness? Anyone have this problem before? Thanks in advance.
How did you determine the problem is with a coolant leak at the heater valve?
There is a main engine wiring harness that goes close to the heater valve. It can be accessed fairly easily from the engine bay. On your truck it runs along the valve cover, past the EGR valve at the rear of the engine. That part of the harness is fairly well wrapped up.
Are you blowing fuses?
-B-
We had some maintance done at the local toyota dealership and thats what they thought happened. We are not blowing any fuses at all. I am hoping that if the harness is only slightly messed up then I could patch the reverse light wires so I can warn people im backing up!
You are going to need an EWD to figure this one out. I would start at the backup lights with a 12v tester and work back toward the engine bay.
-B-
