Reverse electrics engage when lights are turned on
Edmonton, Alberta, Canada
A couple weeks back, my HDJ81 started blowing the same fuse every now and then. The fuse being blown was the fuse for the tail lights (and corners?). This began happening increasingly more frequently until a couple of days ago when I was driving home and all of the sudden the light on the dash lit up and the backup beeper began signalling that I was in reverse. A few seconds later the fuse blew, so I replaced it and carried on like normal, only this time the reverse light and beeping kept happening and didn't stop.
I began to think it was my daytime running light relay that was causing the problems, though I've since disconnected it.
None of the tail lights, brake lights included, work. The only lights in the rear to work are the reverse lights (which come on whenever the marker lights are turned on). When the marker lights are left off, the truck is perfectly fine and drives just like normal. However, when the truck is placed in reverse (and only reverse) with the marker lights and headlights switch in the off position, the two front marker lights and dash lights suddenly come on.
To recap, when you place the truck in reverse with all the lights switched off, its as if everything on the fuse that was (previously) blowing gets activated. Likewise, when you turn the marker lights on, the truck thinks its in reverse. At the same point in time, the brake lights and rear running lights will not turn on, no matter what I've tried.
It seams likely that the two circuits are shorting to each other somewhere along the lines, but where might this be occuring? Where should I start looking? Any guru's out there? :frown:
