restoring or replacing the top & gutter
SoCal
The inside of top is delaminated in a couple places. Will cleaning and recoating w/ resin fix it well enough or replace with new?
Can a new top be found?
The other thing that has me preplexed just now is how to deal with the rain gutter and its relation to the roof. It looks like there is some kind of filler on the outside and this filler, or whatever it is, is cracked and missing in some places. On the inside of the roof at the gutter there is some pretty good rust. Can the top be removed from the gutter and replaced when the gutter is cleaned up?
Or, can a new or reproduction gutter be found?
Does it make sense to mix & match, new roof, old gutter, or original roof, new gutter?
Finally, what actually connects the roof & gutter?
Oh, the final finally, if I have to get new, where's the best source? Live in SoCal.
Vic
Redlands, CA.
Some resin and possibly mat will take care of the delamination. 3m makes a couple of products that will replace the factory sealant, check with your local auto body paint store, they'll have it in stock. The top and rail are riveted toegether with "blind" rivets, similar to what an aircraft has, you can drill them out to separate the two, and they can be reattached with some large diameter aluminum pop rivets, inserted from the bottom up, with backing washers. Cool Cruisers of Texas offers replacement gutter in pieces, they just need to be welded together, you can use just a portion of it as needed, or rebuild to factory spec. Factory gutters have long been discontinued, and were expensive to begin with, near 500 bucks. A little time and labor, and your top can be just like new.
Also Specter has a one-piece replacement fiberglass gutter that they won't ship, so you'd have to take a little cruise west to pic it up. Not so sure how it might hold up vs. CCOT's metal one with a roof rack etc.
