residual coolant removal?
Kelowna, B.C.
Did some searching but couldn't get a hit.
I Joined the "headgasket club" and I am getting things buttoned back together.
There was is a bit of coolant that got mixed with my oil, nothing major just what apears to be 1/4 -1/2 cup or so and it got frothed up in the pump, I cleaned it out best I could but I know there is some in there still.
What is the best thing to add-mix with the first couple of quick oil changes to get rid of the residual coolant.
I have heard, ATF or Varsol or Deisel....what say ye?
Fill up you crankcase with oil but leave room for one to two quarts of regular ATF. I would say not to run it more than 5 minutes then drain it all out. The ATF is a detergent and will clean it out but dont run it too long.
For grins you could even fill up with some inexpensive oil after that and run up to temperature then drain again to get any residual ATF out of it.
Then fill with your favorite oil.
Thanks Murf, I have heard ATF works for cleaning up varnish and deposits but no one can tell me if it will capture the coolant. It makes sense that the detergent would.
I used about a liter of ATF...and drove it home from the shop (about 15min). The ATF thins out your oil enough to drop the oil pressure at idle. I changed out the oil, took another drive and my oil has never been cleaner.
