replacing vent diffusers
Fort Mill, SC
I want to replace the two center diffusers and the passenger side diffuser. Is there a way to do this without fully removing the dash?
I lubricated them with a little soap and pulled them out the cave man way. Bit of a struggle but they always eventually came out & went back in with no damage. Me thinks there's a "correct way" to do it but I don't recall what it is.
Thank you! I didn’t even realize I could pop out the center vent portion! I thought I would have to replace the whole unit. Appreciate the help!
In case it helps anyone else, I found the easiest way to do this is to turn the diffuser sideways, ie. perpendicular to its usual orientation, and it'll just slide right out. In doing this, I also realized the two center ones weren't broken like I thought, they were just turned all the way around so that the handle was turned inside. :confused:
