Wanted to see if anyone has ever replaced the sliding glass without pulling the whole rear quarter panel apart?
This forum has a knack for short cuts when comparing to the FSM procedures. I am keeping my fingers crossed on this one for a friend of mine. He got his rig broken into via the rear glass.
Some punk broke into my 93 last year but I got lucky and found a replacement sliding window at upull for $20.
When I installed it I just used the good old VW bug method...
1. Spray soapy water on the gasket
2. Stick a wire in the groove on the gasket all the way around the window and overlap it a few inches
3. Spray the opening's edges and gaskets with soapy water and place the window in the opening from the outside
4. Have a buddy apply pressure on the window from the outside
5. Pull the wire slowly from the inside all the way around the window making sure the gasket comes in with it(it took me a couple tries to get it all the way around)
I'm not sure that this will work for you, or if it is even the correct procedure, but all is good on my old girl...
