Replacing rubber vacuum hose
Denver
Just got done replacing all the engine rubber vacuum hose. Used the Toyota OEM stuff and it worked great. Seems the truck idles better also. Anyway, couldn't get to the vacuum hose in between the upper and lower intake manifolds.
Any way of getting to this area and replacing the vacuum hose W/O removing the upper intake manifold?
Maybe from underneath? looks like a PITA.
:cheers:
Pete
There's no easy way. Save it for a future maintenance event when the upper plenum is off such as an injector cleaning or head gasket.
:cheers:
Pete
I want to get the OEM hose to do mine to. I've tried to come up with the list of everything I need. Does this sound right?
The small (3.5mm) diameter vacuum hose
1 meter hose is 90999-92004 (will 1 meter be enough?)
PCV valve to Plenum is 12261-66021
TB to the bib on the valve cover is 12262-66021
Anything else?
