Replacing radiator in a '92 with 3F-E?
West of the Pecos
How different is a radiator swap in a '92 compared to what's described in the FAQ for a '96?
I don't have an FSM and my Haynes manual is pretty useless for this.
thanks.
Basically just start pullin' stuff off.
Battery, battery tray, loosen the power steering adjustment bolt and slide that belt off the pulleys for better access, then the fan with clutch attached comes out at the same time as the shroud. May or may not have to loosen the grill and/or headlight assemblies to access a couple bolts.
Dig in already, and post up if you get stuck! :D
Curtis
Thanks CJF!
That's pretty much what I figured, just didn't know if there were any tricks to make it easier or "secret" bolts that were hard to get to. Ordered a new radiator from CDan, so with a little luck I'll get it next week and do the swap next Saturday.
