Replacing oil pan gasket question
Golden, CO
On a 350 sbc I think I am puking oil from the pan gasket. Got one of the one piece rubber seal. Do I need to use some sort of gasket sealer for this type of gasket?
I have used a product called 'Gaskacinch' that is like rubber cement. Paint both mating surfaces with it after everything is clean, wait 5 min, then assemble. It has worked on 3-4 oil pan gaskets I have done (cork gaskets though). I think NAPA sells it. It will let you stick the gasket up on the block, then install the pan with all the holes lined up. If you f-up, you can take it off and re-assemble. Good Luck!
Brian
