REPLACING KEY FOB
Do you have the master key or valet key? If you only have valet key then your ECU needs to be replaced and programmed for a lot of $$$$$$$$$. If it's a master key then you can get a key fob for $15 and laser cut for $60 and then self program it.
unfortunately, no master. i only have 2 valet keys.
Lots of info regarding programming aftermarket keys and fobs on here. I bought an aftermarket key and fob off of Ebay. I was able to get the new key to work following the programming instructions on here, but I was never able to get the fob to work. Maybe it was defective.
Are you sure you have 2 valet keys? Wouldn't that be unusual?
I just purchased 2 of these per someone else here's recommendation, they come cut which is a major advantage but self programming is required. However you do need an original non-valet
I havent had any problems with the replacement keys from Amazon that have the fob built in for that year. Unfortunatly without a master you wont be able to program a key to start the car without a little work.
If you want to add new keys to your ecu you will need to have the eeprom "virginized", this will put your ecu in registration mode and allow you to add your keys as masters. There are locksmiths that can do this, but it isnt cheap.
I can help you virginize your ecu. I offer preprogrammed eeprom chips if you are able to swap them out yourself.
yes, both have no built in fobs, just straight keys. so maybe one is a copy of my valet.
thats why i posted, since most of the threads HAVE at least a master key.
They can still be masters. You need to check them with your security light if it goes off as soon as the key is inserted in the ignition it is a master. If the light stays lit for a second after the key is inserted it is a valet
ah ok, let me check the keys and report back.
Master key is not needed to program FOB for door locks.
I came here to say the same thing, but a couple of people already beat me to it. My LX came with a keyfob and three old-school regular keys. I used the security light trick and found out that I just have a bunch of master keys and no valet. Don't assume it's valet just because there aren't any buttons.
