replacing birfs question
i am going to replace my birf seals. i have some clicking wen i turn tight. i read that if you swap them around it will help this. do i have to replace the berings to or just swap them wat is involved in the swap thanks.
You need to separate the birf from the inner shaft. A search will reveal a few different methods for doing this. It will break the snap rings that holds the birf on to the inner shafts, and then you can pick up two new ones from Toyota, and reinstall your birfs on the opposite inner shafts.
