Replacing belts - problem.
Searched all the threads and didnt come up with this problem listed - so here I go. I bought new belts from CDan and followed the instructions on how to change them. Took off skid plate and took out battery (i know - you dont have to!) and went to loosen the alternator and the belt tensioner.
The problem is - I cant get either one to move. Ive backed out the bolts all the way (Ive taken them out and put them back in - just to make sure I wasnt crazy)
I sprayed the brackets with liquid wrench - but nothings moving. What am I doing wrong?
thanks...
Going by memory...
On the tensioner, you have to loosen the bolt right on the axis of the pulley; did you do that?
On the alt. as well I think there's a bolt somewhere that needs to be loosened besides the adjusting bolt.
Curtis
Yup, loosen the bolt on the pulley so it can slide as you adjust the tensioning bolt.
Same thing happened to me. If you are SURE that you have loosened EVERYTHING and that the alternator should move, then you could do what I did (please note that I am not suggesting you do this. Alternators are relatively fragile. I am just telling you what I did). I put the alternator bolt back in, but did not tighten it. I wanted a pivot point. I took a large hammer with a soft rubber handle. I placed the SOFT RUBBER HANDLE on the alternator, and angled it at 45 degrees toward the engine (in the direction I wanted the alternator to go). I then used a second hammer to strike the head of the first hammer, very softly. I increased the force until the alternator moved. Worked like a charm. Again, the hammer touching the alternator had a very soft rubber grip with a lot of give in it.
Once the alternator broke loose, it swiveled freely on the alternator bolt.
Thanks all. I'm gonna try this again tonight. I'll let you know what I come away with.
I had a nice time almost completely stripping the long bolt that you have to turn in order to loosen the alternator.
And then once I got the alternator to move enough, the belts wouldn't go on. Even with the bolt completely off the whatever.
And then I had a nice time completely stripping the idler pulley's bolt on the A/C compressor set up.
That's the point I decided that I've had enough with crowded engine bays.
Did you loosen everything, like the locking bolts, for instance? It is a pain in the ass, but if I can move my gorilla arms through their, I think anyone could.
I loosened pretty much every bolt on the damn thing. I could get it to move. But I guess even with the really long bolt you have to remove completely unscrewed wasn't enough. I don't know. I don't know if my old belts can handle being taken off and the possibly put back on again. So I'm waiting for Mudrak to help me. He's a god when it comes to knowing how to do things.
I had the same experience when I did my head gasket recently. I wound up removing all of the bolts/nuts from the generator and AC. Actually, I had to replace the AC idler pulley/lock nut and tension bolt as they were frozen together. After I removed the generator lock bolt, adjusting bolt and pivot bolt, I was able to move the generator by gingerly pivoting it with a strategically placed pry bar. I was careful in applying orange penetrating oil to avoid contaminating the generator. When I was done, I cleaned the 10 years of what did not appear to be a lot of surface corrosion and everything went together smoothly.
As it was a head gasket job I think I cleared out the front of the engine including the radiator when I did this although I followed the FS Manual and the FSM does not call for the radiator to be removed.
Hey guys. Your advice worked. I had basically forgotten to loosen the bolt on the pulley. Doh!! Got all the belts done in about an hour. Thanks again to the board!!! Such a huge help!
