Replacement tubs?
NE Indiana
I think I have determined that my little restoration project is best suited if I replace the 3/4 tub. My firewall forward is in decent shape except for the front fenders who have met a few too many trees and rocks not to mention rust. Instead of piecing together a 3/4 tub and fixing what was hacked before me, I think replacement is wiser. From what I've read it seems that a lot has changed in the last 10+ years regarding reproduction 40 body panels and tubs. I do want to stay with steel. I talked to CCOT who has a shipment coming January from Costa Rico. These are known as the Paul Pilgram tubs, who I guess pissed off some people and he is no longer affiliated but the tub comes from the same facility. I put my name on the list for one of these with no obligation, I can back out when they arrive and call.
Can anyone give me first hand recent feedback on a 3/4 or full steel tub replacement? Who did you buy from, good and bad of the experience?
Any help is much appreciated!
Not mine, but in northern California....
Land Cruiser FJ40
What year is your 40?
Locking gas filler door says it's about the same vintage.
Just an idea.
If you need someone to take a look at it, let me know.
Hopefully that other tub worked out, still curious about the original question though. :)
Appreciate the offer!
He sent me a few more pics. Too much rust for my taste since that is exactly what I’m trying to get away from. Not saying it’s not worth it. I’m also 2k miles away. He thinks it’s a ‘73.
No problem. I've seen it on CL the past few days and hadn't had a chance to take a look at it myself.
In case anybody else might be interested, here are the additional pics the seller sent me. Located No Cal.
Bottom of both sides, rear quarters.
Well, that's not gonna get him $1,000! :frown:
That's what I thought but to each his own.
He does sound very motivated in case you really are interested at the right price.
How is the retirement practicing going for you?
Well, it's just a little ways off but I have a great job with lots of flexibility and low stress that makes the countdown enjoyable.
Personally if just the rear corners and sill are rusted out it's not a bad price. It's OEM and all the fixed nuts should be there. Hard top should bolt on. Prices I'm seeing on newly built tubes and fitment issues would rather deal with the replacement of the sill and corners. I would ask to see pictures of the inside of the wheel wells. I see where a CB antenna was mounted where a larger hole would be for a reverse light on a 73. In the rusted corners believe I see holes from a 74 rear reflectors. If so should have the support brackets for the factory roll bars. Don't believe all replacement tubs have those if any. The B pillar is door catch is for the early doors. 75 believe the dash is the same. 76/77 brake moved to a bracket hung off the bottom of the dash also with a seat belt and blank light. 78 the brake/seat belt lights moved up into the dash face.
