I thought the xp motor was 6hp?
It is; don't know why I put 12 but I corrected my post, thanks for catching it.
I'd like to buy one of those 191 dollar motors - can you give me the contact info please? You can PM me if needed.
Thanks!
The Warn 6hp XP motors are going for 211.31 at amazon.com. It is warn Part number 68608. Free shipping too. This is what I put in my M12k.
Will my existing old 8274 solenoids/wiring/etc still work with the Warn 6hp XP motor?
Yes, although "in" and "out" were reversed on the wired remote until I reversed the cables to the F1 and F2 terminals on the new motor.
I just bought an Albright contactor for mine, just need to figure out where to put it now. Doesn't look like it will fit under the solenoid pack cover because the remote cable connector inside the cover is in the way.
Which contactor did you buy? Warn's albright contactor is pn 34971 at about $200.
From what I read, the Warn contacter is made by Albright exclusively for Warn, is a triple pole and therefore will stand more abuse than the DC88 that is a twin pole.
Thanks, Dan
After a lot of reading on Pirate and some Land Rover sites, I found out that the Warn P/N you mentioned is for their industrial winches that see almost constant service. Yes, the three poles would be an extra margin of safety, but the two-pole Albrights are designed to fail in the open position so your winch is not supposed to be able to run away. At any rate, I decided that the Albright P/N 90-14452 which is the one they make for Superwinch would be sufficient for my needs at half the cost of the Warn industrial. Thanks to Pinhead for pointing me to Summit Racing, where you can buy them for $97.
https://forum.ih8mud.com/winching-recovery/464180-warn-8274-winch-solenoid.html
Superwinch 90-14452 - Superwinch Replacement Solenoids - Overview - SummitRacing.com
Great info guys and much app. from a non computer man, just got back from a windrock Tenn. trip and my warn went south at a bad time. need some parts too. I did see a new 12000e spit its guts and gears trying to extract a 80 series from the rail trail. not a good sight when it had just lost a front and rear chromemoly axels
