Replace thermostat as preventative maintenance?
Colorado Springs, CO
I'm going to be flushing the cooling system and replacing most of the hoses soon - including the PHH. Should I replace the thermostat at the same time? Or am I at the bottom of the bathtub curve and just fixing something that ain't broke? It's a 93 FZJ80 with about 145K on the clock.
I assume replacing the thermostat is straight forward. Anything I should know?
FWIW, I haven't had any cooling issues.
Yes.
You should be sure to get a gasket with the OEM thermostat. IIRC, the gasket is sold seperately.... could be wrong on this. The jiggle valve goes at 12:00 o'clock. Use care in fitting the gasket. It's a big O-ring. The housing is AL so the torque values are low.
-B-
Beowulf said:
Yes.
-B-
Thanks - can anybody with an FSM tell me what the torque values are?
pg. EG-176 of 97 LC FSM:
"Install the water inlet with the 3 nuts.
Torque: 21 N-m (210 kgf-cm, 15 ft-lb)"
By my calculation, 12 x 15 ft-lb = 180 in-lb. torque if your wrench is calibrated for in-lb.
Excellent - thanks!
