Instead of an engine swap (see "Bad #2 Cylinder & Piston. Now What?"), I'm considering dropping the oil pan with the engine still installed and replacing #2 piston.
First question, is this possible? Looking at the FSM and under the LC, it looks like there is room to get to the stuff. If possible then. . .
What all to replace? New rings, all bearings (main & connecting rods), oil pump, more?
I looked at the cylinders and they look good. I'll hone them a bit for the new rings.
Before I start ordering from C-Dan, I'd like your opinion. Can't find info on this procedure here, so am wondering if it's possible.
Any thoughts would be greatly appreciated. In the meantime, I'm going to clean off the top of the block and feel in the cylinders again (and again and again).
