Replace EGR Components?
Knoxville
Hello, my '96 FZJ80 with 202K miles is getting the upper part of the motor reworked (valve job, timing chain, gaskets, seals, etc.). Also, after researching on MUD I am going to take care of several other maintenance items at this time (injectors, coolant system, PHH, starter contacts, water pump, belts, hoses, etc.)
My question is about the EGR system components (such as the 2 VSV's, control modulator, etc.). While the intake is removed (and cleaned) is there any merit in replacing any of these components while they are readily accessible? I like to prevent future headaches while doing a project but I don't have a good feel about the life expectancy of these items. So far, I have not experienced any P401 or P402 code problems. Thanks for any input.
The EGR VSV can be removed without removing the intake plenum by using about 3' of extensions and getting it from underneath the truck. There are a few threads with the details. I think it costs around $120 if you want to replace it now. If you want to defer the the job and use the 3' extension method, I would losen the bolts and snug them back up so they can be easily removed in the future.
