It is very possible to fix the crack. Hoewever, where does the crack run, and how long is it. To fix it you will need a good cast iron rod preferably nickel based, such as 99Ni or 55Ni. Then you will need to "V" prep the both sides of the crack. Next weld it in tiny sections, and peen the weld either with a chipping hammer or a needle scalar or even an air chisel. Just make sure not to get the cast iron too hot by running long beads, and allow plenty of cooling in between welds. Now, if the crack runs along any sides of the tranny where there is oil on the other side, you will need to drain the oil, and use contact cleaner to get all of the oil out once you have made the v prep. However, it is best to take the gears out so that you can weld the inside of the case also. IMHO if you have little or no experience welding cast iron take it to a reputable weld shop and have them make the repairs because fixing cast iron is a very difficult task for the inexperienced.
