Removing tub
Lable EVERYTHING.
Take A LOT of pictures, so that you are not out here, trying to have someone that is a thousand miles away, tell you how to put it back together.
Get some form of containers for the heardwear for EVERYTHING, or IT WILL get lost... ;)
Masking tape and sharpies....
Good luck!
-Steve
nuclearlemon said:
zip lock baggies...two boxes and lots of sharpies
Its how we did in production shops, I took it right into my shop and it works better than anything I know.
Zip locks, bins, tag your wiring with every item removed, pics of the dash for re assembly.
The wiring harness is really helpful, most everthing is built to length so you can figure it out quite easily.
Put the body on saw horse or something, assemble dash standing in the tranny hump area, this will save time and be much more comfortable.
Do as much firewall pre assemblie as possible, think long and hard, take a note pad and describe dissassemblie step by step.
The worst mistake I ever made was installing a aftermarket 40 series air condition unit in the cab fairly early, I must of pulled that thing 5 times before finished.
The more you think the smooth things will go.
Pre assemble evething on the frame prior to dropping the body, brake lines, fuel lines, wiring harness etc.
