Removing The Throttle Body
Bend, Oregon
I received a $400.00 box of tune-up stuff from cdan about 2 weeks ago and plan to dive in and start this weekend.
-(4) new radiator hoses (no phh, still looks healthy)
-Thermostat
-Cap, rotor, wires & plugs
-EGR modulator
-Air intake hose & air filter
-PCV & (2) hoses
-Throttle body gasket
-Starter rebuild kit
I have a pretty good understanding of the cap, wires & plugs (loosen the heater hose bracket to get to #6 - thanks Dan for the advice), starter rebuild (can the plastic clips that hold the wheel well curtains be removed without destroying them?) and I have about 60 pages of threads about coolant flushing.
I also want to chase down my code 71 and plan to replace the EGR modulator, change out as many vacuum lines I can get to and remove and clean the throttle body. I am a little uncertain about the throttle body removal. I have not read through the FSM about this yet, but hope it is a straight forward procedure.
If anyone has any additional advice about removing the throttle body for cleaning, please let me know. If it is all in the FSM and even a :banana: can do it, please disregard this thread and go about your day.
Thanks,
Riley (as noted below, 1994 LC w/ 194,000 miles)
Yes, the plastic clips, at least on my truck, were re-usable. I thought they were going to be useless afterwards, but after gently removing them by prying with a screwdriver, they popped out and were not damaged. Can't help you with the other stuff as I haven't done all that PM yet. Good luck.
Thanks for the info! The day after I ordered from Dan, I remembered the wheel well flaps and that I should have ordered some new clips.
Riley
The first time through takes a little more time on the TB removal in order to figure out how things are hooked in like the throttle cables. It's all pretty much in the FSM. Couple of suggestions you might find useful: I always tape off the PS side nut on the throttle cables and loosen the one on the DS side. This holds the same position, so you don't have to screw around with any adjustments later. No need to drain the coolant as stated in the FSM. You'll find it easier to hook the bottom middle throttle cable before reattaching the TB. Go easy on the bolt torque. If you're TB has never been removed, then you may find your bypass hoses stuck on pretty good. You can usually take a pair of pliers and grab the hose over the nipple and rotate/work it back and forth to break the "seal", then should slide off without too much trouble.
:beer:
Rookie2
The coolant hoses that hook up to the throttle body were very stuck when I did it. Be patient and work them off slowly (Rookie mentioned twisting, it definitely helps) and you shouldn't have any trouble.
Thanks Rookie & Nater! I guess I need to start reading the FSM. I was hoping for some pictures of what needs to be disconnected (yes, I am a picture whore!!!).
Attached are a couple of pictures of my throttle cables and filthy engine (plan to clean as I do the PMs). Some of those cool little arrows pointing out the nuts you are talking about would be great.
I plan to change the wires and spark plugs at the same time, so I am just trying to get a game plan.
Thanks again,
Riley
Alright, the "little arrow" request was a bit much...
I just do not have access to the site on the weekend (extremely slow dial-up at home) so it will be just me and my FSM.
Like everything else I have attempted on the LC, just take your time and it all will make sense.
Thanks,
Riley
There are basically two nuts on each cable that "clamp" the cable positioning plate and hold the positions as you see them in the first picture. I tape the ones that are to the left of that plate (passagers side) to keep them from getting spun back and forth during the removal process. If you don't you'll have to reset it later so that you're getting the proper throttle response.
:beer:
Rookie2
Thanks Rookie! After I found the pictures and posted them up I figured that was what you were talking about.
DT, I need to get a digital camera. Maybe I will just use one of my old point & shoot 35mm and scan them in.
The first time I do something new on the LC, I spend more time worrying about not breaking anything then taking pictures.
I promise that once I get it done I will at least mention any gotchas I find.
Riley
I have some of the same anxieties when working on the rig. The pressure is a little higher when it's your only mode of transportation and come hell or high water, Monday morning she's got to be operational. Best advice I can give you is make sure you've alotted plenty of time for the repair. There will be hiccups and things will take longer than you think, so just have plenty of time to work it out.
:beer:
Rookie2
I just did some of the above last week.
I did not remove anything to do spark plug #6, or any others for that matter. I just pushed on the hose a bit and it went in and out quite snuggly. (that sounds pretty funny when reading it back)
Be careful with the little bypass hose on the top of the radiator. It is just to the left of the main hose. I snapped mine while doing the belts, but read that several people did it while trying to reach plug#6. I got to the plug from the passenger side. I used a bucket to step on and I have long arms. Don't know if your average sized person can reach it that way. Only other suggestion is to tape your plug socket to the extension so that it does not come off in the spark plug chamber. I also used a swivel adaptor or whatever it is called on #6. That way I did not have to push as hard on the tube.
For those who wonder, I did not repace the radiator as a result of the broken fitting. I tapped out the broken piece and threaded in a 1/4"npt X 5/16" barbed fitting and slipped the hose over that. So far so good.
Good luck
FWIW, there's a tool in the vehicle tool back for the spark plugs. I haven't used it (didn't know about it until after), but looks like it'd work pretty good.
:beer:
Rookie2
:beer:
Rookie2
Yes, there is such a tool. Yes, it works great - just like owl puke on an greased icy log. No, the '92 and '94 spark plug wrenches are *not* interchangeable. I tried :o
Thanks again to all for the advice! I hope that I can get at least the plugs/wires/cap & rotor done this weekend. My side business (detailing cars) is starting to pick up (65 degrees and sunny here in central Oregon). I will try to document as much as I can and post back the outcome.
:cheers: Riley
While doing this, I also pulled the top of the intake and did the following:
(1) New heater hoses up against the fire wall and, yes, the PHH !
(2) Replaced all the vacuum hoses
(3) Pulled the injectors and had them ultrasonically cleaned at my local injector shop
(4) Checked the valve lash (just need throttle body off, not the intake)
I seem to remember needing a torx fitting for the EGR valve to hold the studs ? Does that sound right?
Ran like a top afterwards and no more Code 71 ! Although my EGR port from the valve to the top of the intake was plugged.
Cheers,
R.
Ran out of time this weekend but ended up doing the following:
-Installed new spark plugs, wires, cap & rotor
-Installed new air intake hose & air filter
-Installed new PCV valve, grommet & hose
-Installed new valve cover vent hose
-Installed new EGR modulator
I pulled and cleaned all of the vacuum lines leading into and out of the EGR modulator (all still pliable - no cracks). I also used a can of compressed air and blew out the metal tubes around the throttle body.
I did not have the time to remove the throttle body, but hope to do it soon. Also, I could not get the temperature sensor connector apart, so did not get it cleaned. Cleared the code 71 (did not come back on over the weekend - I realize that it probably will come back again).
Here is the question: I could not get air to blow through the tube in the picture below (red arrow - picture from before changing everything). I fished a wire in the tube, but no air would come out the throttle body. On the one next to it I could hear air blowing into the throttle body.
Thanks,
Riley
shameless bump...
And another question... what is the easiest way to disconnect the EGR temperature sensor? I really do not want to rip the wires out of the connector.
Thanks,
Riley
Thanks,
Riley
Unplug it at the connection and cuss while you try to get a wrench on the 14mm nut holding the sensor in. I used a stubby wrench. The 94 is harder to get to than the 95+.
